1 members (MikeE),
70
Mod | | | Forums66 Topics128,031 Posts1,055,436 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I just put the bed back on the truck and now don't have any brake lights. The wires were never cut...the lights were unbolted from bed and left intact while I did some work, and then bolted back on. I have all other functions including both turn signals, flashers and when lights are turned on at switch....just no brake lights :confused: Maybe the stoplight switch?? (Bed was recently painted and they are LED)
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | | Anonymous Unregistered | | Anonymous Unregistered | If they worked before I'd check the ground first & then your brake light switch. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | check your grounding the lights ground thru the bulb housing and you changed something
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Blue 50,
On a conventional rig, turn signals ARE brake lights...a bed paint job would lead one to believe that lights lost their ground, but from your description, everything actually seems to work. The brake switch, although not involved in the painting procedure, is what fires both rear lights off simultaneously.
Stuart | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I left town after asking my question and just had a chance to look at my truck again. Looks like it was the stoplamp all along....I did some yoga moves and found that the arm that is released, when the brake is applied, is shot. The brake lights come on when the arm is moved by hand....never replaced one before....I love it when I learn something new :p
Blue 50
