0 members (), 89 guests, and 0 robots.
Topics128,049
Posts1,055,637
#1026867 05/07/2014 1:27 PM
Hi, I just got my 50 cabover running and it had a exhaust leak at the head to manifold and I also saw it had a crack in the exhaust manifold, I removed it and was going to weld the manifold but when I got it apart it was almost broken in half. ok well I had another coe ex manifold that was not broke, I need to remove about 8 broken studs and mill things flat again but I need the gasket that goes between the intake and exhaust, being and updraft carb the normal gasket for trucks is not even close. anybody know where or a part number that I can get to make this work again? this truck ran pretty good for something that didn't run for years and I want to drive it when I am done with this exhaust leak, thank you, Dan (baldybenny)
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
baldybenny #1026886 05/07/2014 3:26 PM
I think caseman44 makes them
His name is Harold 610-767-8370
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
baldybenny #1026887 05/07/2014 3:32 PM
3B Offline
Hy baldybenny, could you post a picture of the manifold area you need the gasket for? A lot of the overhaul gasket sets contained updraft manifold gaskets as well as the more common downdraft manifold gaskets, I may have what you need, the other place you might try is Olsons Gaskets, Sandy Olson is a nice guy and he has been known to make one off gaskets for people, hope that helps.
baldybenny #1026975 05/07/2014 8:22 PM
Thank you Goob! I'll call him, Dan
baldybenny #1026976 05/07/2014 8:22 PM
3B I sent you a PM. Thank you! Dan
baldybenny #1032679 06/01/2014 3:00 PM
Thank you 3B! Without your help I couldn't be driving the COE! Thank you again! ,Dan
baldybenny #1032804 06/02/2014 2:32 AM
3B Offline
Hy baldybenny, you're more than welcome!
