8 members (cmayna, baldeagle, Bill Hanlon, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | I am trying to determine what king pin set I need to get for my 65 C-60. I don't know the weight rating of the front axle. How do you determine this? Does anyone have any part numbers out there?
1965 Chevrolet C-60 292 Flatbed 2008 GMC Sierra SLE Z71 Crew Cab 1992 Chevrolet C1500 Cheyenne 5 Speed 2001 Harley Davidson FLHT Electra Glide Standard
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy IHBoilermaker, According to my Moog catalog there were three different front axles for a 65 C60 the 5000 lb. the 7000 lb. (FO70), and the 9000 lb. (FO90) the 5000 lb. axle kingpins are 1.109" diameter and 6.343" long the 7000 lb. axle kingpins are 1.2494" diameter and 7.890" long the 9000 lb. axle kingpins are 1.4335" and 1.1860" (tapered pin) and 8.750" long the Moog p/ns for the different kingpin kits follows the 5000lb. pins are p/n 8492B the 7000lb. pins are p/n 8491B the 9000lb. pins are p/n 8462B The following are RockAuto prices for the Moog parts 8492B $26.79, 8491B $33.59, 8462B $122.79 The following are Napa crosses to the Moog p/ns and Napa prices 8492B= Napa p/n NCP 2621016 $68.40, 8491B= Napa p/n NCP 2621017 $111.60, 8462B= Napa p/n NCP 2621406 $197.10, hope that helps. | | | | | Joined: Nov 2013 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2013 Posts: 35 | Thanks for your help. I appreciate it.
