Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Tronman, Stewart2, MickeyP, 2 invisible), 144 guests, and 4 robots.
Topics128,288
Posts1,058,581
Members48,492
I have a 49 pickup, I was told that it had been converted to a 12volt system and I have noticed that there is a resister on the block that I assume keeps from frying the points, but I have lost all my dash lights and my gas gauge is pegging full when I turn on the key. I have been reading some of the problems that guys are having with their sending units and hope that mine may be different. Do I need to put a resister somewhere in line to keep my gauge from pegging full all the time or do I just start checking out grounding problems, float problems and wiring problems? If I do need a resister, where exactly does it need to go, I am sure with the heat that is generated with these resisters, that will be a big concern. So I would appreciate any advice on this gas gauge situation, Thanks.
the only way the dash lights would be affected is if they weren't changed to 12V bulbs, easy fix - for the gas gauge, if it always only reads full it's likely been fried already by not having the dropping resistor .... those resistors don't get hot enough to be a big concern, usually just mounted under dash in the line from power source to gauge [see EL110 here]
Fuel gauge pegged with ignition switch on is a classic symptom for no ground to sending unit.
