| | | Forums66 Topics128,154 Posts1,056,857 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I have a 49 pickup, I was told that it had been converted to a 12volt system and I have noticed that there is a resister on the block that I assume keeps from frying the points, but I have lost all my dash lights and my gas gauge is pegging full when I turn on the key. I have been reading some of the problems that guys are having with their sending units and hope that mine may be different. Do I need to put a resister somewhere in line to keep my gauge from pegging full all the time or do I just start checking out grounding problems, float problems and wiring problems? If I do need a resister, where exactly does it need to go, I am sure with the heat that is generated with these resisters, that will be a big concern. So I would appreciate any advice on this gas gauge situation, Thanks. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the only way the dash lights would be affected is if they weren't changed to 12V bulbs, easy fix - for the gas gauge, if it always only reads full it's likely been fried already by not having the dropping resistor .... those resistors don't get hot enough to be a big concern, usually just mounted under dash in the line from power source to gauge [ see EL110 here] Bill | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Fuel gauge pegged with ignition switch on is a classic symptom for no ground to sending unit.
