6 members (Hotrod Lincoln, klhansen, Mike B, Otto Skorzeny, IHPWR, Jims46), 50 guests, and 2 robots.
Topics128,030
Posts1,055,423
Members48,422
#1026566 05/06/2014 3:58 AM
I have a 51 3100, ls-1 , and a American auto wire chassis harness. My headlights, running lights, low beam, high beam , turn signals all work. My issue is that when my lights are on my brake lights does not work?? Does not matter if it's park or full lights. If I turn the lights off the brake lights work fine?
Hi, Pa51, On my truck I used reproduction stock type tail light mounts and found out that the ground path through the mount did NOT work.( I did check with a multimeter and it said I had a ground path) I had to install separate grounds from the frame to the tail light mounting bolts. Hope this helps, Brian
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
If the large and small filaments are switched, it may not be possible to see the brake lights.
1951 1 Ton Completed
Most aftermarket wiring companies have a great tech line. You might want to call them.
My 46 GMC on Photobucket
46gmcpu #1028461 05/14/2014 12:18 AM
Reversed the wiring on the lighting and everything is good ???? I was told by tech line that it did not matter which wire was going to wich color as long as they matched.
