1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | I probably need to adjust the clutch on my 61 GMC half ton with the 305. it doesn't take hold till pretty close to the top and I certainly am not looking forward to trying to replace it. can any free travel be felt with the hydraulic slave cylinder setup or should I just see if I can back any adjustment off till it hopefully engages at about half travel? I have in the past adjusted mechanical linkages but I know later model hydraulic clutches on Fords I have owned were pretty much self adjusting with no adjustment available best I remember | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I have found it more difficult to adjust a hydraulic clutch than a mechanical clutch. You should be able to get under the truck and make sure that the through out bearing is not against the fingers on the pressure plate when the pedal is at rest. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Like Don says its best to check the freeplay at the slave cyl. You should have about 1/4 in freeplay in the fork. Its best to pull the rod out & clean up all the threads so the adjustment turns freely. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | I'll try to get time to get under there this afternoon and get'r done. I replaced the rear springs yesterday. one side was a bear to get the old one off- plenty rust /broke bolt, broke spring etc. other one came out pretty good- likely it had been replaced sometime. it was a different diameter than the left one. I put a set from a late 60's I think back in. they were a little thicker and larger diameter and 2" shorter than the old ones, but I made a spacer spool to make up the difference. it stands up straighter and holds weight better now. probably too 6 hours or more labor but well worth it. I'm gett'in there. | | |
