7 members (NJC, David Bush, Oswald, Otto Skorzeny, GRNHydra, 2-Ton, Rusted Nut),
76
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I have a friend who has a '51 3100. It has push button exterior door handles and vent windows. Please refresh my memory as to what year did they start push button door handles and which year did they start vent windows.
Thanks Craig
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I have a friend who has a '51 3100. It has push button exterior door handles and vent windows. Please refresh my memory as to what year did they start push button door handles and which year did they start vent windows.
Thanks Craig To confirm he truly has a 1951, use the VIN BUSTER All 1951 trucks had the first year vent windows and flip handles, 1952 was the first year for push button handles. Does it have the 1947/51 80 MPH speedometer or the 1952/53 90MPH? | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | George, It has the correct 80 speedo. As far as a vin#, the title states it as being a serial number which is:
CA 49xXXxXX
So, is it possible that the PO had put '52 doors on the rig?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Any 47-55 door could be used with any 47-55 cab (as long as door-year-matching latches/catches are used). What are all the letters/digits in the ID? CA 49 looks like a CA re-title code? It does not look like a 1951 code? | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tim, On the driver's A pillar, riveted vertically in the usual spot. Sorry but my friend is hesitant in giving all the numbers but as I said earlier the only letters are at the beginning being CA, space and then numbers. The plate has a Calif state logo in the background, so yes it seems to be a re-title from the state.
CA 49xXXxXX
