2 members (Ponchogl, Shardean),
56
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | Got a question... im trying to convert the front of my 46 1/2 ton pickup to tube shocks, if anyone has done this can ya tell me what you used for bottom mounts and what you did on the driver side with all the steering arms in the way?? | | | | | Joined: May 2010 Posts: 42 'Bolter | | 'Bolter Joined: May 2010 Posts: 42 | On my '46 I used the OEM lower mounts from an AD truck front axle ('52). Both shocks mount forward of the axle, so no interference from the steering arm.
Daryl
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | What X said. My AD frame is similar to the '46 - used levers - just need AD cups and lower mounts BUT make sure the lower mounts are the kind that have a bend in them. Earlier ones don't have a bend. | | |
