| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 9 New Guy | | New Guy Joined: Apr 2013 Posts: 9 | Hey guys, I missing the washer that holds the spring ( I think it holds the spring ) under the steering wheel. I have everything else. Here is a pic from Dad's posts that shows the spring, I am missing, the washer. https://picasaweb.google.com/103098517476416596131/UntitledAlbum12#5566158133092138738What do you guys suggest I do for a washer? I am hoping to make one, or tack one, but I have no idea the purpose of the washer. Craig | | | | | Joined: Apr 2013 Posts: 9 New Guy | | New Guy Joined: Apr 2013 Posts: 9 | Well, don't all respond at once!
I found a flat washer with 40 little slits on the inner ring, and pounded it over with a 3/4 inch black nipple. Slits bent over and did the job. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Good fix. That is an internal star washer by the way. What year and model truck do you have? It helps the rest of us understand what you have and need. The washer helps keep the "cup" flat and prevents the nut from distorting the cup when it is tightened.
Steve H
| | | | | Joined: Apr 2013 Posts: 9 New Guy | | New Guy Joined: Apr 2013 Posts: 9 | 53 GMC. And it worked well. The spines got a bit scratched as it went over, but the wheel goes on ok. Thanks, I thought it was just for pressure on the bearing, but I wasn't sure. | | |
