8 members (Gdads51, Otto Skorzeny, moparguy, Greg_H, Bill Hanlon, Shade Baby, DaveV, 1 invisible),
102
Mod | | | Forums66 Topics128,266 Posts1,058,318 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Anyone know if a 2005 Tahoe 4x4 frame swap is reasonable as to length and width on a 46-54 Suburban? Anyone tried it or done it? Thanks for any input! If not this frame some other 4x4 frame?
| | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | VetteCrazy, I haven't done it but I've read a few posts of guys that want to try it. Take a look through the Hipo shop forum here. The tahoe wheelbase looks very close to your suburban. the tire width you may need to accept a lifted look. the underside of the suburban is almost flat cab-front to back. you will need to Fab every bodymount bracket attaching the body to the frame. with luck there maybe a kit designed to fit a Tahoe. Look at my photobucket below it may give you a idea of what is involved. My sons ME/BS degree takes priorty to our progress, plus he built his Truck..to check out some of the mods to do to our suburban.
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | looks like Trailblazer is an option with three inch extension if someone has done one with maybe 4x4 set up??? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You are ruining my life with this talk of frame swapping.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | I guess good article but no real details--wonder if they could be gotten?? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | you may be able to write to them or email them and ask, it's worth a try. I saw in person at the world will show in Kansas City last year, it was a nice suburban. The grille wasn't quite right and the headliner didn't fit correctly.i watched some youtube video's after they finished it. 1953 suburban 1953 burb 1953 burb street rod Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | Trail blazers also come with a straight 4200 motor, great engine. Ive considered it for a swap. An engine and chassis swap from a wrecked gmc envoy or trailblazer would be a cool swap. should be very close in wheelbase. | | | | | Joined: Sep 2012 Posts: 10 New Guy | | New Guy Joined: Sep 2012 Posts: 10 | I have a 51 burb and have been working on a frame swap with a 2001 silverado z71, the frame has required some mods, we had to shorten it, relocate the torsion bars, antilock brake system and fabricate every body mount and buy a manual transfer case | | | | | Joined: Jul 2006 Posts: 104 Jack of all trades and a Master of None! | | Jack of all trades and a Master of None! Joined: Jul 2006 Posts: 104 | Ed at EZChassisSwap takes that vintage of truck and slaps it on a S-10 frame. Might be another alternative for you. | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Thks haven't seen that before. Ed at EZChassisSwap takes that vintage of truck and slaps it on a S-10 frame. Might be another alternative for you. | | | | | Joined: Nov 2005 Posts: 324 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 324 | I have a 51 burb and have been working on a frame swap with a 2001 silverado z71, the frame has required some mods, we had to shorten it, relocate the torsion bars, antilock brake system and fabricate every body mount and buy a manual transfer case Why did you relocate the torsion bars? I am considering a similar swap. | | | | | Joined: Aug 2009 Posts: 22 New Guy | | New Guy Joined: Aug 2009 Posts: 22 | Just FYI the EZ Swap makes the body sit very high. Although it is a complete and good looking assembly of mounts and includes all that you need, and would buy one for a pickup, it made my burb sit to high for my liking and I did a lot of modifications to his brackets to get it down. And Ed told me it would sit higher that a pickup.Great guy to deal with too. Great for a pickup as you can deal with the kick up over the rear axle raising the bed floor. If i had it to do over again i would use a Heidt's front end, box the frame and install the rear end and springs of my choice. Just my 2 cents.... | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | Looking at their web site it looks like an option. Like to see some pictures that are more detailed as to installation of the kit. | | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Vette , What is end use for your burb? Do you want off road 4x4 or a modern drivetrain w IFS etc?' If latter I'd consider boxing existing frame w some type of IFS kit or sub frame as I don't see how to offset the rear kick up inside without major modifications inside rear floor area of the burb. As said above easier to swap frame on a truck as you just raise the bed floor. With boxed frame you can set up rear anyway 4 link, rear on top of existing leafs and no fab needed for mounts. To me that is a much quicker way to be back on the road. Good luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | IFS with maybe 4 link on rear but not 4x4. I once thought of Trailblazer with 5.3 and 4x4 original chasis modified for Burb body but that may be more than I want to do. Hot Rod article on Trailblazer 2x4 under 53 Burb looked good but the adaptation of fit for frt suspension looked extensive. | | | | | Joined: Jul 2011 Posts: 34 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 34 | Hi Guys, I have a friend at Progressive Automotive in Baltimore, Ohio building a frame for my 1946 Suburban. I'm actually putting a Duramax and Allison transmission in it!
Russ | | | | | Joined: Sep 2012 Posts: 217 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 217 | | | |
