6 members (Cletus1950, Gdads51, cmayna, Jon G, JW51, 1 invisible), 108 guests, and 1 robot.
Topics128,130
Posts1,056,370
Members48,441
#1024734 04/28/2014 3:33 AM
Hello, I hope someone can help.
The crankshaft pulley on my truck is loose and makes an awful rattling noise. I can see where the rivet holes have been elongated. It doesn't look like there's anything else wrong except for this looseness. Is there a simple fix for this or do I have to replace the whole harmonic balancer? The motor came out of a '53 power-glide car, so it might be hard to find the right parts for it.
Thanks in advance.
Once the rivet holes get loose, there's virtually no fix other than replacing the damper. I'm not even sure if the shops that specialize in rebuilding them can rehab one with that kind of wear. Rebuilders are very fond of their work- - - -bring lots of cash! What width belt are you running?
I'd suggest putting an ad in the "parts wanted" section. Somebody here probably has the part you need or can be of assistance in finding one. I build up a new 2-groove balancer with the narrow belt with readily available over the counter parts, but it requires a little machine work on the hub to make the belts align properly. Even considering the machining, the cost is a lot less than the balancer rebuilders want for their services.
I've got a 5/8 inch belt with an alternator conversion. I guess I need to figure out if any 235 dampener with 5/8 groove will work or will I have to find one specifically for a '53 power-glide. Thanks for the response.
According to the parts book, the only difference between the
'53-'55 235 and the earlier 235 was the 5/8" vs. the 3/8" pulley.
Both are 7 1/4" dampers, no distinction between P/G or Std.
DG
Denny G
Sandwich, IL
