1 members (LAROKE),
127
Mod | | | Forums66 Topics128,196 Posts1,057,393 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yeah, I see that all the time. And an embarrassing footnote... Until a few years ago, I thought this was just normal so when I started on my current project, I started making a special metal channel to neatly slide the radiator into. Before I did it, I came here and just ask how others did it. It pays to ask questions here.
Not only is it possible to leave the radiator alone, on the new engines, you can get an adapter plate for the water pump to raise it to the center of the radiator. I am very thankful for this forum and the people here. I learn something new all the time. | | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Red, Well maybe so with a 3speed,or a car 4 speed But you,d have to be a good Magician to get that SM 420 still coupled to the bell house and engine between the floorboards and the X member,out in 1 piece!!! AIN,T Happening Regards steve sr.
| | | | | Joined: May 2014 Posts: 2 New Guy | | New Guy Joined: May 2014 Posts: 2 | Sounds like the stuff my dad,rip,used to do on the farm, bailing wire a BFH and no money but he made things work I learnd a lot of how not to do things from him,, | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | PO on my '41 took small sheets of Masonite and pop revited them to the up rights in the back of the cab. He then screwed the wire mesh used for stucco to the panels. And then, you guessed it, bondo'd the whole thing into one solid mass. Added about 200 pounds to the cab weight. I ended up replacing the whole cab - too much bondo and not enough metal left.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | Reading these brings back memories of repairs we did on my dads trucks (and some I had). This was back when a pick up was used as a truck and run until you had to pay the scrap yard to take it. The amount of abuse and cobbled repairs they would endure and still start and run every day amazes me now. We have to remember in most cases, the PO's weren't restoring, they were using. Plus, they saved them for us to try to straighten out their messes. My 2 cents worth. John | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Duct tape over the body rot in the wiper cowl and then a coat of bondo to blend it in so you didn't see it. Can't understand if he spent that much time doing a mickey mouse repair, why he didn't just fix it correctly?
