1 members (GMCJammer51), 122 guests, and 5 robots.
Topics128,266
Posts1,058,386
Members48,485
#102461 09/07/2007 12:54 AM
Apprentice
Apprentice
what is the size for original 1950 battery cables?. what length?
rrf
#102462 09/07/2007 1:47 AM
I do not know what gauge was original, but if you are still running 6 volt, you need 2/0 (00) gauge for your positive cable. The ground straps are probably 2 gauge. I am not sure of the exact length right off the bat, but you want it was short as possible, just long enough to reach.
#102463 09/07/2007 5:44 AM
I just had a set of cables made for a 1954 6400 truck I'm picking up on Saturday. The positive cable was 32" center of terminal to center of terminal and the ground was 15" measured the same way.
I had the cables made up at the local NAPA store and they were out of stock on the 2/0 so I went with the 1/0. Stock was 1 gauge so 1/0 seemed like more than enough.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
