1 members (GMCJammer51),
122
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 27 Apprentice | | Apprentice Joined: Apr 2003 Posts: 27 | what is the size for original 1950 battery cables?. what length?
rrf
| | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | I do not know what gauge was original, but if you are still running 6 volt, you need 2/0 (00) gauge for your positive cable. The ground straps are probably 2 gauge. I am not sure of the exact length right off the bat, but you want it was short as possible, just long enough to reach. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | I just had a set of cables made for a 1954 6400 truck I'm picking up on Saturday. The positive cable was 32" center of terminal to center of terminal and the ground was 15" measured the same way.
I had the cables made up at the local NAPA store and they were out of stock on the 2/0 so I went with the 1/0. Stock was 1 gauge so 1/0 seemed like more than enough.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
