| | | Forums66 Topics128,049 Posts1,055,678 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | The Truck Shop Manual says on section 12-26, "Insert a stiff wire in small hole on lock face". My 53 has two holes. Does it matter which one? Also,there is a gap between the face & the dash. Was a rubber seal there originally? Thanks, Steve | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | there is a small button that will line up ...link... no seal the gap is for the light | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, Steve, The gap is to let out light. If you have a original style switch it will have a place for a bulb holder on the back. ( So you can find the switch in the dark) The bulb is on the instrument light circuit. On which hole to use try one then the other then both. If I remember right, you should feel or hear a lite click when the wire is pushed in. I installed a new tumbler about 8 years ago. Have fun, Brian
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | | | |
