7 members (klhansen, 87GN, tclederman, Stovebolt48, Peggy M, baldeagle, 1 invisible), 117 guests, and 1 robot.
Topics128,048
Posts1,055,666
The Truck Shop Manual says on section 12-26, "Insert a stiff wire in small hole on lock face". My 53 has two holes. Does it matter which one? Also,there is a gap between the face & the dash. Was a rubber seal there originally? Thanks, Steve
there is a small button that will line up ...link...
no seal the gap is for the light
Hi, Steve, The gap is to let out light. If you have a original style switch it will have a place for a bulb holder on the back. ( So you can find the switch in the dark) The bulb is on the instrument light circuit. On which hole to use try one then the other then both. If I remember right, you should feel or hear a lite click when the wire is pushed in. I installed a new tumbler about 8 years ago. Have fun, Brian
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
Thanks fellas
