2 members (Barry Martak, Wally / Montana), 167 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
#1023900 04/24/2014 2:30 AM
I have a t5 I am going to put in my 1948 3600, what clutch do I need? What drive shaft do I need?
I think that you will just need the same size clutch as with your old transmission but the splines on the shaft are different so you will have to get a clutch to match the splines on the t5 shaft. I have never done this myself but that is what I have been told. I never even thought about the drive shaft needing to be changed but it probably will.
Gene
1959 Apache
I don't know how deep you are into this issue, but you will have to go to an open drive shaft and the best one would probably be the one that matches the rear axle you choose.
My 3/4 ton has an open drive shaft
You will need to match the front U-joint saddle to your old drive shaft. You will need a good measurement from the rear saddle to the front and take that to a drive shaft shop along with the old drive shaft. They will make the drive shaft the right length and install the correct front saddle for you. Good time to make sure the splines are good as well. Last time I did this I took both drive shafts with me along with the measurement. They were quick and good about it. Mine was a Chrysler transmission to Chevrolet third member. Shop never even blinked. What I got back was balanced with both sets of U-joints and painted. Good splines as well. For the clutch, use the pressure plate and get a friction [censored] that matches the T-5 no problem.
Steve H
OK some one explain why "disk" came out "****". I was so good this time no bad words at all.
Steve H
Sorry, I did use the "Chrysler" thing didn't I. My bad.
Steve H
