0 members (),
162
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | With the steering box in the truck it is difficult to get to the large nut (worm bearing adjuster) on the end, Is there a specific tool still available that i can purchase to get at it? | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | a punch and small hammer work great if you can't find a stamped steel wrench to fit. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Are you sure you need to mess with that adjustment? That adjustment should not need readjustment once set.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Dave wanders all over the rd and the steering has alot of play in it, everything else is new shop manual says you need to adjust in both spots to get The pay out. It is this weekends project. Last thing to do before i order my rims and tiress. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I work on a lot of steering boxes and that adjustment is unlikely to be the problem. Have you checked or replaced the pitman shaft bushings? I assume you have looked at the king pins and tie rod ends. Most play can be removed from a steering box, if the bushings are good, by the adjuster on the side cover. Wandering all over the road is commonly caused by toe-out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | What size tires and wheels are on it currently? Tires that are too wide for the wheels will also cause road wander, especially if they're underinflated.
Bill Burmeister | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Currently everything is stock with regards to the rims and tires, it is lowered with sids drop axle 4". The wander is the same before and after the drop, king pins and tie rods, steering arm are all new as well. Everything i have read in multiple posts sounds like an adjustment is what i need. Im confused on the pitman shaft bushings as this is the first i have heard or seen a post on them? How do you check and replace these if i find that is the issue? So are you saying i can do one adjustment with out the other? in regards to the steps in the shop manual? All help is appreciated. Thanks Steve | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | What you want to check is how much fore and aft movement you see in the pitman shaft when someone rocks the steering wheel back and forth. If the bushings are bad or there is wear on the shaft or both the shaft will move. You should look at this Overhauling the truck steering gear link. And yes to your question, all adjustments are not needed.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Thanks I will check this weekend, if my memory serves me correct i think that is fine. I wiill post over the weekend as to the results i got. Steve | | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | FINALLY got around to making the adjustment took 2-1/2 turns in to get to 2-1/2lbs of tension. We will see after we drive it a bit this weekend. Thanks All!!!! | | |
