| | | Forums66 Topics128,187 Posts1,057,325 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | This is for the orginal set for 55 thru 59 chevy trucks.
Instrument/Tail_LP in Headlight switch -AGA 3AMP
Radio -------------SFE 7.5amp
Brake LP?
Fog LP-------------SFE 14Amp
Air conditioner?
Backup LP----------SFE 9AMP
Hood Lp------------SFE 9AMP
Heater switch------SFE 9AMP
SpotLP-------------SFE 9AMP | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | geez, ask for the moon! there's not that many fuses on the original panel [only 7], and some of those weren't options for the truck most 5-9 years [AC, clock, spot] note that there's 'accy' fuses [3] with a total of 7 terminals, no doubt all small stuff like hood light went to a single fuse Heater [delux] 9amp Fogs 14amp Backup isn't specified, small, like 3-7 amp others?? well, it's a start Bill | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | The Owners Manual for a 56 lists 9 fuses. Ed | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | only 7 of which are on the fuse panel but good find on the values, need to carry a spare pack of 9amp's Bill | | | | | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Thanks, Next question I guess you guys knew this was coming! Where can you get this type/size fuse? Look at the local auto parts chain stores 10amp 15amp 20amp and 30 amp all they had Thanks again for the information! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, it doesn't hurt to have slightly higher ratings, if a fuse blows there's a major problem that'll usually be drawing the max, like a short!
but look around, maybe a radio shack or such, other sizes are around
Bill | | |
