0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
This is for the orginal set for 55 thru 59 chevy trucks.
Instrument/Tail_LP in Headlight switch -AGA 3AMP
Radio -------------SFE 7.5amp
Brake LP?
Fog LP-------------SFE 14Amp
Air conditioner?
Backup LP----------SFE 9AMP
Hood Lp------------SFE 9AMP
Heater switch------SFE 9AMP
SpotLP-------------SFE 9AMP
geez, ask for the moon!
there's not that many fuses on the original panel [only 7], and some of those weren't options for the truck most 5-9 years [AC, clock, spot]
note that there's 'accy' fuses [3] with a total of 7 terminals, no doubt all small stuff like hood light went to a single fuse
Heater [delux] 9amp
Fogs 14amp
Backup isn't specified, small, like 3-7 amp
others??
well, it's a start grin
The Owners Manual for a 56 lists 9 fuses. Ed
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
only 7 of which are on the fuse panel grin
but good find on the values, need to carry a spare pack of 9amp's cool
Next question grin
I guess you guys knew this was coming!
Where can you get this type/size fuse?
Look at the local auto parts chain stores
10amp 15amp 20amp and 30 amp all they had
Thanks again for the information!
yes, it doesn't hurt to have slightly higher ratings, if a fuse blows there's a major problem that'll usually be drawing the max, like a short!
but look around, maybe a radio shack or such, other sizes are around
