| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | Can anyone tell me if the hoses come out of the front wheel cylinder toward the front or rear of the car?The manual seams to indicate the rear but suppliers part numbers show the front. I put them on toward the rear and then noticed the originals were toward the front. ??? Thanks | | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | Also the master parts manual indicates by casting number on the cylinders the hoses mount from the front of the cylinder. That matches my original parts. Can anyone comment on this? This problem has got me stalled. (1951 3100) | | | | | Joined: Mar 2014 Posts: 161 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 161 | My 51 3100 has both hoses come out towards the front.---Jack | | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | Thank you. The old car manual 29-54 master parts list casting numbers shows them toward the front and the 29-57 master parts list casting numbers show them toward the rear so I was confused.I will put them toward the front. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Two on the front and one on the rear. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
