3 members (TUTS 59, JW51, Jon G),
114
Mod | | | Forums66 Topics128,095 Posts1,056,480 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | I'm going to be using a firewall mounted brake pedal (if anyone has a recommendation for a junkyard setup that will work, please share).
So what do I do about the clutch pedal? I'd like to have that hanging, too, and not have it through-floor.
| | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | Be aware that hanging pedals need a lot of support, particularly for brake operation. The firewall alone is not strong enough to withstand a hard push during an energetic (panic!) stop. On the round track cars, we usually scavenged a complete clutch and brake pedal and pivot assembly from a 1970's or later pickup truck, and built a well-braced structure to mount it between the dash and the firewall. Clutch linkage can turn into quite an exercise in geometry unless you can go with a hydraulic release system and add a single-reservoir master cylinder for the clutch. One system I used a lot on the dirt track cars was the master and slave cylinder setup for a mid-1960's Dodge pickup. Those parts are still available from some of the online parts vendors. Try a 1965 Dodge D-100 clutch master and slave cylinder as a reference. Jerry
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Be aware that hanging pedals need a lot of support, particularly for brake operation. The firewall alone is not strong enough to withstand a hard push during an energetic (panic!) stop. On the round track cars, we usually scavenged a complete clutch and brake pedal and pivot assembly from a 1970's or later pickup truck, and built a well-braced structure to mount it between the dash and the firewall. Clutch linkage can turn into quite an exercise in geometry unless you can go with a hydraulic release system and add a single-reservoir master cylinder for the clutch. One system I used a lot on the dirt track cars was the master and slave cylinder setup for a mid-1960's Dodge pickup. Those parts are still available from some of the online parts vendors. Try a 1965 Dodge D-100 clutch master and slave cylinder as a reference. Jerry If it went to the firewall they would have to have support brackets, for certain. But I can't think of any way to hook up a hydro clutch to the 216 clutch assembly. Can anyone? | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | If you want a hydraulic clutch you can mount the slave cylinder in place of the rod that connects to the through out arm. It takes some fabrication but it can be done. Then you need a master cylinder and a line from the master cylinder to the slave cylinder. As Jerry mentions you will need to stiffen and strengthen the firewall if your going to mount the clutch and brake pedals to it. | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | late 90s chevy truck Hydro clutch Master and slave cylinder, that pushes the fork. There is even a bellhousing that holds the slave cylinder or design your own bracket. that's what's on my DD & I love it. What Jerry said beef it up. Fire wall mounting suggestion: We used the donor trucks bracket& get the Steering column clamp for free. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | late 90s chevy truck Hydro clutch Master and slave cylinder, that pushes the fork. There is even a bellhousing that holds the slave cylinder or design your own bracket. that's what's on my DD & I love it. What Jerry said beef it up. Fire wall mounting suggestion: We used the donor trucks bracket& get the Steering column clamp for free. You used the bellhousing or designed your own? When you say late 90's Chevy truck, can you be more specific? What truck did that firewall bracket come out of? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just out of curiosity, why are you wanting to change the clutch/brake pedals to a hanging assembly instead of the stock style?
Bill Burmeister | | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | Just out of curiosity, why are you wanting to change the clutch/brake pedals to a hanging assembly instead of the stock style? In the hopes of having lower, adjustable pedals, and to get the master cylinder higher up. Am I wrong in thinking I'll gain some space and be able to get the pedals lower like a more modern vehicle?
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The 60-62 Chevy pickups came from the factory with hydraulic clutches that had the slave cylinder mounted on the right (or passenger) side. They had seperate clutch and brake mster cylinders that are firewall mounted.
Evan
| | | | | Joined: Mar 2013 Posts: 186 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 186 | A friend of mine did a 54 pu afew years ago and used a mid 70s firebird for donor car. He uesd the clutch brake pedal assy, bracket and all with very little mods.this also set him up to use a firewall mounted brake booster . Worked very well was almost a direct bolt in. Hope this info helps. Wher there is a will theres a way. One learns to be creative! | | | | | Joined: Feb 2014 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 46 | 60-62 chev v8 belhousings for juice clutch are rare on west coast,from what i remember.last 1 i boughyt was in late 70s.was for 292 in 62 panel.that rig with 4 speed ate bellhousings fast | | | | | Joined: Mar 2014 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2014 Posts: 159 | On my AD panel I used 1987 chevy truck pedal and column. the fit is awesome. I reused the 87 pedal, dash bracket , brake booster and column. If you can find a manual shift version of this I highly recommend. I am plating/bracing the firewall also. I believe the parts I am referencing are through a wide set of years.
