| | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Good Morning! I just installed new brake shoes, drums, etc. and I need to adjust the hand brake. Adjusted it as per the service manual but 8 clicks is the end of the lever travel. Can soemone suggest an easier way to do it? I was thinking of going to the half way point (about 5 or 6 clicks at the hand lever) and adjusting the cables so that the wheels don't turn. Is this a good idea? Should be as long as the wheels turn freely when the brake is released. Have I missed something? Many Thanks | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Please let me have your suggestions... Thanks | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Make, model, year truck?
Standard equipment, or, have modifications been made?
| | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | My pickup is a 55 Series II model 3200. It is all original and all of the new brake drums, linings, wheel cylinders and hand brake cables are NOS OE parts. No modifications. I'm just looking for some suggestions as to how best to adjust the hand brake so that it brakes evenly. Tried the service manual directions but when I pull the hand brake lever back four notches and try to adjust the cables for an even drag at the rear wheels, one wheel always has more drag because of the differential. The other wheel is not slowed by the differential and turns easier. On the road, one wheel always locks up when I pull the hand lever. Also, when on the road at say 20MPH, I can pull the hand lever all the way to the end of it's travel. That can't be right. Any suggetions would be greatly appreciated... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | do it the way the manual states, first make sure the brake shoes are adjusted properly - the "4 notches" is when you first connect the cables to the cross shaft by hand pull, then you need to pull the handle further until one wheel has a heavy drag, meaning it's hard to turn [harder than the diff would cause], then try evening out the drag - and note with the handle pulled out 9 notches the rear wheels should be locked, it shouldn't be possible to 'pull the hand lever all the way to the end of it's travel' .... if you have one wheel locking up when road tested, loosen that side or tighten up the other one  Bill | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Hello All, It's finally spring and I took my truck out of the garage for my first drive in 2014! I evened out the tire pressures and checked all fluids then hit the road. Everything is fine with the exception of the problems I've had all along. Engine noise above 2500 RPM and one rear wheel locking up when I brake hard. I'm going to readjust the valves to see if that changes the engine noise but the rear brakes have me stumped How can I adjust them so it brakes evenly. Apparently,going by the subjective drag isn't working. Have bled the brakes again - no air AT ALL. Still, just when I think the drag is equal, one wheel still locks up. Brake shoes, drums, wheel cylinders, etc. are all new. Is it the diff or maybe the parking brake adjustment? Parking brake is another issue. I hope when I get the braking evened out the parking brake will also work better. As it is, when I use it one wheel locks up too. Thanks | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | When adjusting the brakes did you turn the adjuster until it locked the drum up tight so you couldn't spin it at all, then back off to the desired 'feel' or did you just adjust till it felt right after installation?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | But that page is for a 1.5 and 2 ton rear not the 1/2 ton... are they the same?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | So you are sure that there is no difference in the shoes between the two sides? Also, the front shoe and rear shoe have not been switched on one side? When you turn the wheel backwards on each side, do they act the same? How about if the drums are switched side to side? | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | I turned the adjuster until it locked the drum up tight then backed off. Tried to get the same drag at both rear wheels but apparently that didn't work. Thanks for your input! | | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Thanks for your input. Did everything exactly as decsribed. Think maybe my problem is that the service brakes aren't/were not adjusted correctly. Will be taking everything apart - again - today and will have another go at it. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | short shoe goes to the front of the vehicle.
Tommy 59 apache 1/2t 261 short stepside | | |
