1 members (delky), 130 guests, and 3 robots.
Topics128,062
Posts1,055,854
Members48,428
#1022496 04/18/2014 12:43 AM
I have a 235 engine on this 1950 3100 with a Rochester carb. This past winter I had the carb rebuilt by a reputable mechanic. Since then the engine is sputtering. It starts and idles great and if I give it gas slowly it runs good. If I do it quickly it sputters and is gutless when changing gears. I checked my vaccuum advance on the distributor and it works fine when I rev the engine. Timming is dead on. The engine ran good before the carb rebuild, just thought it be good to rebuild it since I didn't know it's history. Any ideas.
DJRoy #1022509 04/18/2014 1:25 AM
Pull the plugs and see if you are running rich or lean, my guess would be accellarator pump.
DJRoy #1022538 04/18/2014 3:07 AM
V
V Offline
1st and easiest test is to make sure the correct carb to manifold spacer gasket was used. The proper gasket should have short openings radiating out from the center hole to allow vacuum to get to the power piston.
2nd easy check is to make sure the throttle linkage is connected to the short excellerator pump linkage on the outside of the carb. If the pump doesn't squirt a small stream of gas into the venturi when the throttle is depressed the engine will stumble and hesitate on excelleration.
Other checks require disassembling the carb to make sure the proper sized BB's are in the correct passages.
Also make sure everything associated w/the carb mounting is good and tight and theres no vacuum leak.
Good luck
Dave
DJRoy #1022552 04/18/2014 4:09 AM
Almost sounds like the accelerator pump in the carb isn't working...
