7 members (Gdads51, Charles in CA, Chip O, RaNfLaS, Otto Skorzeny, TexasFarmTruck, 1 invisible),
94
Mod | | | Forums66 Topics128,288 Posts1,058,548 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 107 Shop Shark | | Shop Shark Joined: May 2009 Posts: 107 | All, I have a specially built fuel tank under the bed, in the frame of my 1952 3100 series. We have installed three sending units and they get fried! The last one was tested in each stage of it being installed, from start to finish. All three have worked for about 2 hours of drive time or so then pegged the needle.
Any thoughts on what could be causing this? I know a bad ground can be an issue.... Thanks everyone for taking the time to help me out....
Take care, Steven No one can drive us crazy unless we give them the keys.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | need more info, usually it'd be the gauge that gets fried .... 6V or 12V? original gauge? correct ohm rating for gauge?
Bill | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Fried? Or is the Resistance wire coming apart? You might have too much road shock with the present mounting or some cheap sending units. You most likely have a wire that is getting pinched and shorting the sender to ground.
Steve H
| | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | I am the one doing the work on it and have a couple other threads/comments about this problem. The sending units (2 of the three)are 30ohm units from Macs, the first one I thought I fried while welding some straps onto the new gas tank to secure the gage wire & fuel line. I testing the unit thoroughly when I set the sending unit in it and when I had everything together the gage quit working. I had to tear the bed off etc and replaced the sending unit (another macs), tested it thoroughly and put the bed back on etc and it worked for a while befor quitting. I pulled the bed and found it fried just as the other one that I thought I had ruined welding. I bought a different sending unit (RCI), tested it thoroughly and put the bed back on and it lasted for a while and has quit. I'll have the truck by the weekend and we'll see whats' what. The gage is an autometer. The other senders were fried, the copper winding had turned blue from the current. I can't understand how it is happening because they are just a basic wheatstone bridge circuit and only milliamps can flow until the needle and sender resistance become equal. If any of you guys have any idea - serious or bazaar - speak up, thanks oj
A shop is where you wash your hands before you pee.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | maybe you have the power to the wrong terminal on the gauge ... hey wait, isn't an Autometer gauge higher resistance?
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | Isn't Macs a Ford supplier? | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | Isn't Macs a Ford supplier? Yes, you're right. The sender came from LMC - at the same time I was working on a '48 Ford F3 and had a nasty time of it with Macs' stuff not fitting and working right. Autometer offers 3 different fuel level ranges, the one I chose was 0-30ohm and it tested proper with the sending unit in hand operating thru its' range. I would've bought the sending unit from autometer but they don't offer one for that range. Keep the thoughts coming, they are helping.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Isn't Frawds of that era positive ground? | | | | | Joined: Oct 2013 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2013 Posts: 98 | I've seen everything now! The truck arrived a few days ago dripping fuel out of the tank onto the bed of the rollback, I could see what looked like a puncture. By the time it was unloaded the tank was empty otherwise I'd never had known the tank had a leak and would've pulled the bed to replace the sending unit. Pure luck it was leaking. I crawled under to find a pinhole in a brandnew steel tank, I cleaned around the hole and saw a blueish halo around the hole. When the muffler guy welded the muffles (they run right under the tank)he missed with the mig wire and ran it into the tank! That was what shorted the other sending unit! The tank didn't leak until it was filled completely after it left my shop. I patched the hole and just put some gas in it and the gage reads proper without leaks! Pure luck that it leaked when they delivered it, if all the fuel had run out i'd never have known about the hole and would've pulled the bed off, removed a perfectly good sending unit and would've been totally dumbfounded.
Steve H
| | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | So if I understand it properly, there is now a functioning gas gauge in a truck that has mufflers that run just under the gas tank. I hope the mufflers never develop a leak or over heat! | | |
