8 members (52Carl, Steelonsteel, TexasFarmTruck, Samantha, TUTS 59, Shade Baby, TexasJim50, Jims46),
87
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | Thanks Stuart, I was testing and it had continuity, I would expect the resistance of the system to change with position of the float just out of the box but I will check it out, I get F reading with the gauge installed at all times wheh ignition is on. I could check the wires, the ground to the tank is fine but I will check the gauge to sending unit wire for further diagnostics. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | How ya doin’ doc, haven’t heard from ya for a while. I don’t know ’55 and I don’t know GMC but I do know ’50 Chevy and here is a link to a couple of things that I ran into when I rebuilt my sender. Now remember this was a 6v system. “I tested the range and it runs from 1.9 ohms to 38.1 ohms. Couple of pics here, take a look.” http://rides.webshots.com/photo/2810310490098611668EngTlM The thread was here if you care to read it. http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=002823#000000 Hope this helps ya out Paull. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | denny: I'm ok but too busy with life, haven't forgotten about you either. What is your mailing address? I will check the resistance again, just go off of the terminals? Do you want to try the 235 in your beast? call me at 708-341-5036. How do you rebuild the unit/ | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well Paull my sender was an after market unit, it must have been replaced at sometime in the past. I had to actually make some of the components to replace the broken parts in mine. I spent way too much time on it and should have just bought a new unit. It's just that I'm retired now and on kind of a limited budget. I have more time than money to do these things. If you have a defective unit I really think that the best route to take is to simply order a replacement. Right now at the top of my list is finding a 4.11 Eaton gear from a '67-'72 3/4 ton so I can at least move along with the traffic. I am considering a 235 in the future and if the right one comes along for the right price I might just haul it home. Right now I’m planning on rebuilding the original 216 short block this winter. Denny Graham Sandwich, IL
