3 members (TooMany2count, Bill Hanlon, Gray_Ghost), 32 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#1021535 04/14/2014 1:36 AM
Will a starter drive from a 12 volt starter, fit on a 6 volt starter?
Brian
1955.2 3100 Truck
55shaker #1021539 04/14/2014 1:46 AM
probably, but 6 & 12v use different tooth count ring gears, so you'd have to change the flywheel too
55shaker #1021549 04/14/2014 2:32 AM
No, they won't.
55shaker #1021565 04/14/2014 3:31 AM
cletis is correct.
My Blog
55shaker #1021921 04/15/2014 8:17 PM
The early 6 volt truck starters and later 12 volt truck starters took different drives. 6 volt starter armatures had straight spline shafts and the later 12 volt starters had twisted splines. The teeth on the gear were different as well. It is possible however to replace the drives with different ones. Example: you have a late style 50s 12 volt starter and want to install it on your late 40s truck. I can supply a drive that will be twisted on the armature shaft but have the gear from the late 40s starter drive. Its making a starter that never existed and a little of a custom job but it can be done. Starter modifications like this allow you to keep the original flywheel.
55shaker #1023273 04/21/2014 4:06 PM
I ordered 2 12v stater drives while i needed a 6volt starterdrive. Thats how i learned that it doent fit. 12volt is smaller than 6 volt.
Chevrolet 3100
Year: 1951
engine: inline 6 217CI
Transmission: Manual 3-Speed.
12Volt.
