| | | Forums66 Topics128,035 Posts1,055,441 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Will a starter drive from a 12 volt starter, fit on a 6 volt starter?
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | probably, but 6 & 12v use different tooth count ring gears, so you'd have to change the flywheel too
Bill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | The early 6 volt truck starters and later 12 volt truck starters took different drives. 6 volt starter armatures had straight spline shafts and the later 12 volt starters had twisted splines. The teeth on the gear were different as well. It is possible however to replace the drives with different ones. Example: you have a late style 50s 12 volt starter and want to install it on your late 40s truck. I can supply a drive that will be twisted on the armature shaft but have the gear from the late 40s starter drive. Its making a starter that never existed and a little of a custom job but it can be done. Starter modifications like this allow you to keep the original flywheel.
| | | | | Joined: Mar 2014 Posts: 195 Shop Shark | | Shop Shark Joined: Mar 2014 Posts: 195 | I ordered 2 12v stater drives while i needed a 6volt starterdrive. Thats how i learned that it doent fit. 12volt is smaller than 6 volt. Chevrolet 3100 Year: 1951 engine: inline 6 217CI Transmission: Manual 3-Speed. 12Volt. | | |
