| | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | You mean where the axle is or the black line is? The black line is the stock location so yes, it's a bit forward.
And I can't weld on the perches or set the pinion til the cab is on and I can mock up about another 600 lbs (fuel, bed wood, people in the cab). | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | This might be helpful, specs for the 53 truck: http://chevy.oldcarmanualproject.com/chevyresto/53060.htmAs you can see the wheel is a bit forward in the rear fender. I don't think you want it any more forward than stock. The measurements might make sense and be helpful. You are correct about the perch and pinion angle, you need to have the frame loaded. Hopeful the picture will be helpful. Let us know how it goes.
Steve H
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | This might be helpful, specs for the 53 truck: http://chevy.oldcarmanualproject.com/chevyresto/53060.htmAs you can see the wheel is a bit forward in the rear fender. I don't think you want it any more forward than stock. The measurements might make sense and be helpful. You are correct about the perch and pinion angle, you need to have the frame loaded. Hopeful the picture will be helpful. Let us know how it goes. That is a lot of help. The axle could definitely be moved back some without it being a big deal (might even look better). I can't tell if that 36 1/2" measurement is axle to bumper or axle to rear of frame though.
| | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | I put a 12 bolt rear end in my 50 and used the weld-on spring perches from ClassicParts.com, and used the hole located near the end of the perch (as opposed to the center hole) on the head of the leaf spring retaining bolt, and it located the axle exactly 116" from the front axle. Carl
| | | | | Joined: Oct 2013 Posts: 367 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 367 | I put a 12 bolt rear end in my 50 and used the weld-on spring perches from ClassicParts.com, and used the hole located near the end of the perch (as opposed to the center hole) on the head of the leaf spring retaining bolt, and it located the axle exactly 116" from the front axle. Carl Carl - which hole? The one towards the front of the truck/perch or the back? | | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | There are 2 holes in it. One is in the center and one is near the edge. I welded the perches to the axle so that the hole located on the edge is nearest the front of the truck and placed the leaf spring allen head bolt in that edge hole. It is kind of hard to wrap your head around because the original axle had an off-center rubber mount, and the factory springs are not bolted together in the center (front-to-back). Carl
