6 members (rfs56trk, frogfarmer, Bill Hanlon, 50Chevy3100, Buckeye998, JoergK.), 369 guests, and 2 robots.
Topics128,160
Posts1,057,054
Members48,463
#1021181 04/12/2014 2:29 PM
Is there a way to convert the original 6 volt radio to 12 volts? I am planning to rebuild a 1947-1950 unit and have converted my truck to 12 volts from a 6 volt system. What parts would I need to make the conversion?
1970 VW Beetle
What I do is take the power transformer from a 12 volt Buick radio and install it. Then, I switch the heater leads on four of the tubes to make two pairs in series, and feed the 12 volts to each pair. The 6V6 I replace with a 12V6. I think you can buy 12 volt versions of all the tubes from Antique Electronics Supply. You would have to check on that. Also, I replace the vibrator with a 12 volt solid state unit.
The old Buick/Olds radios are not as popular as the truck radios and they usually can be picked up for much less. They don't have to be complete or look nice either.
1951 1 Ton Completed
Moderated by  truckernix
