5 members (Charles in CA, Steelonsteel, Shaffer's1950, 52GMC35424JD, Hotrod Lincoln), 91 guests, and 3 robots.
Topics128,049
Posts1,055,665
#1021178 04/12/2014 2:18 PM
Leo
Offline
Moderator
Moderator
I'm not sure if this practice is still done. My synchros aren't working so well,(SM420) thought maybe double clutching might help.
Leo #1021182 04/12/2014 2:37 PM
Did you get that 90 weight gear lube? Did it help at all? If you replaced the GL5 with the 90 weight it make take a few trips to clean out the old lube from the synchos. As far as double clutching, I have done this and sometimes it helps. If you need new synchos try Drivetrain.com. They have all the gaskets and parts for the SM420.
1970 VW Beetle
Leo #1021195 04/12/2014 3:14 PM
Where I live double clutching is a vital skill so as not to get rear ended as NOBODY comes to a complete stop or even has patience for anybody that does. dang
You Tube
Leo #1021196 04/12/2014 3:26 PM
Some of the newer transmissions specify Synchomax or Synchromesh gear oil. It's just a GL4 gear oil. Supposedly the friction modifiers is GL5 oil are too agressive for the synchronizers.
Just something to think about.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Leo #1021229 04/12/2014 6:38 PM
Originally, I needed to double clutch into high gear of my SM420. It was kind of fun but I started to think about left-knee-longevity after having a little surgery on it.
I found that just pausing for an instant in neutral with the clutch pedal still depressed before completing the shift into high worked just as well.
Leo #1021251 04/12/2014 8:47 PM
Double clutching to engage high gear must be only for the purpose of getting by with a worn synchronizer drum???
My stock 3 speed column shift transmission has a non syncro first gear normally requiring a complete stop and clutch pedal depressed until the gears stop moving before shifting. To drop into low while rolling I synchronize road speed to engine speed (estimating what the RPM would be if in gear) release the clutch in neutral, depress again and if they match it drops right into gear. Maybe I misunderstand the term as I thought this procedure was all about getting into low on a roll. ohwell
You Tube
Leo #1021260 04/12/2014 9:55 PM
You should be able to do the downshifts with double clutching but it sounds like you really need new synchros.
1951 1 Ton Completed
