2 members (55shaker, Peggy M),
78
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I would like to get a definitive answer about the routing of the heater hoses if you do not use a heater. I have a 49 pickup and want to smooth out my firewall. I will not be using a heater at all. Will it divert the flow of coolant if I simple plug up the hole in the water pump and the one in the thermostat housing or do I need to use a small hose to connect these two openings. I know nothing about the water jacket and how it flows, also do I need to install an over flow container for the radiator, I seem to be losing radiator fluid and it appears to ne coming out of the over flow tube running down the side of the radiator. I do not have a thermostat in my system at this time, is necessary to run one? As you all can see I do need some advice on this cooling system thing, sure would appreciate any help on this subject. Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can put plugs in the outlets for the hoses. An o-flow bottle is a good idea. Use a 4 or 7 lb. pressure cap. You need to run a therm. A 160 or 180 degree. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | definitive answer: plugs would have been factory for no heater, so there's no need for looping a hose
yes, you really should have a thermostat, the system was designed for one, for one thing it restricts the flow until the stat temp setting is reached, that is, it sets the minimum temp the engine operates at .... if you're constantly topping up the coolant you're likely filling it too much [common], it needs room for expansion, so cold leave it 1-2" down, a bit less when hot, but any time you fill it right up it'll spit some out when it gets up to temp
Bill | | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | Thanks, that's what I needed to hear | | |
