8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY), 126 guests, and 1 robot.
Topics128,109
Posts1,056,253
Members48,437
#1020094 04/07/2014 5:44 PM
I am thinking about taking the ends off so I can fit the center section in my sandblast cabinet, but I am wondering if I'll need special rivets to put it back together and if alignment will be an issue?
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
I had to make a mounting bracket for my 58 GMC grill so removed the other for a template.
I just made sure the rivets I used were sized for the holes and thickness of the material.
I took the opportunity to make sure all surfaces were in epoxy primer prior to assembly.
Give me ambiguity
or give me something else
the vendors used to have a special kit to replace the rivets with screws and nuts, instead of a "head", the screws had a small flat plate, don't know if you could find those, but works fine
