| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | I am thinking about taking the ends off so I can fit the center section in my sandblast cabinet, but I am wondering if I'll need special rivets to put it back together and if alignment will be an issue? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I had to make a mounting bracket for my 58 GMC grill so removed the other for a template. I just made sure the rivets I used were sized for the holes and thickness of the material. I took the opportunity to make sure all surfaces were in epoxy primer prior to assembly.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the vendors used to have a special kit to replace the rivets with screws and nuts, instead of a "head", the screws had a small flat plate, don't know if you could find those, but works fine
Bill | | |
