0 members (),
64
Mod | | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Can someone help me out on my ignition switch, on how it's connected and where the wires connect to. I have a 1959 GMC 270 1/2ton pickup with a turn key and push button start. Thanks | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Napco59, I have linked the diagram for a '58 with start/run key switch. If you visualize your pushbutton in series in the 'start' line that goes to the solenoid, it might resemble your system. This isn't perfect, but it might help. Good luck. Stuart http://www.classicchevytrucks.20m.com/wiring.jpg | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | this might work better - Chevy with a foot stomp, but the GMC should be the same colors, and the push sw will be like Stuart sez, but to a terminal not linked on this pic Bill | | | | | Joined: Jun 2002 Posts: 53 Member | | Member Joined: Jun 2002 Posts: 53 | Thanks Stuart and Bill for the info. Can't wait to get the truck running again. | | |
