| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 107 Shop Shark | | Shop Shark Joined: May 2009 Posts: 107 | All, I have been looking for the correct that is on the 1947 - 53 Chevrolet. This is the rubber located on the control arms under the dash that attach to the Vacuum wiper arm? Or is it as simple as the correct size round rubber grommet?
Take care, Steven No one can drive us crazy unless we give them the keys.
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | These vacuum wiper arm grommets are available through many of the early Chevrolet truck parts suppliers: Chevys of the 40's, Classic Truck Parts, LMC, etc. Cost, less than a couple of bucks.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | I have a '47 3100 that I'm bring back into service many of the features.....Wipers being one. My on/off linkage was jerry-rigged with wire and ties. They worked but you had to get it "just right". Nothing quite like crawling on your head and trying to reach up to install those &*^ little grommets! You can barely get one hand up there let alone two to 'press' those grommets in and seal the edges. Now I'm talking about the grommets and the on/off control lever. It seems you are talking about the grommets linking the motor to the actual wiper bases. The grommets and control rod were very cheap, the install....priceless! I'm probably going to remove the motor and disconnect the arms to the wipers to bring the wiper body down to where a mortal can install that little bugger. My first option tho is to try a bit of soap on the grommet to help 'Persuade' it along. ;-)
Tim is right, grommets are easily found and inexpensive. Might be a little challenging to get them in. Good Luck! | | | | | Joined: May 2009 Posts: 107 Shop Shark | | Shop Shark Joined: May 2009 Posts: 107 | Thanks for the help. I found what I needed from Jim Carter/old chevy trucks.
