Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
All,
I have been looking for the correct that is on the 1947 - 53 Chevrolet. This is the rubber located on the control arms under the dash that attach to the Vacuum wiper arm? Or is it as simple as the correct size round rubber grommet?
Take care,
Steven
No one can drive us crazy unless we give them the keys.
These vacuum wiper arm grommets are available through many of the early Chevrolet truck parts suppliers: Chevys of the 40's, Classic Truck Parts, LMC, etc. Cost, less than a couple of bucks.
Tim
1970 VW Beetle
ok, thanks!
Take care,
Steven
I have a '47 3100 that I'm bring back into service many of the features.....Wipers being one. My on/off linkage was jerry-rigged with wire and ties. They worked but you had to get it "just right". Nothing quite like crawling on your head and trying to reach up to install those &*^ little grommets! You can barely get one hand up there let alone two to 'press' those grommets in and seal the edges. Now I'm talking about the grommets and the on/off control lever. It seems you are talking about the grommets linking the motor to the actual wiper bases. The grommets and control rod were very cheap, the install....priceless! I'm probably going to remove the motor and disconnect the arms to the wipers to bring the wiper body down to where a mortal can install that little bugger. My first option tho is to try a bit of soap on the grommet to help 'Persuade' it along. ;-)
Tim is right, grommets are easily found and inexpensive. Might be a little challenging to get them in. Good Luck!
Thanks for the help. I found what I needed from Jim Carter/old chevy trucks.
Take care,
Steven
Moderated by  ndkid275, Phak1
