Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Woogeroo, klhansen, jay d, 1 invisible), 130 guests, and 2 robots.
Topics128,288
Posts1,058,577
Members48,492
#1019156 04/03/2014 2:54 PM
Have a 235 from a 62 impala in my 49 1/2 ton and I am noticing when I start the engine cold I am hearing a distinct valve clattering and as the engine gets warm the clatter goes away to the point I can't hear it at all. Is this a concern or can I expect this out of a 52 year old engine. Thanks for any advice on this subject
red49 #1019172 04/03/2014 4:02 PM
Most likely that noise from a cold 235 engine with hydraulic lifters is not uncommon and it might not be abnormal.
How do you adjust the valve lash/lifters?
red49 #1019174 04/03/2014 4:06 PM
I'm frustrated over the same thing. Taps until I get some heat into the motor or the lifter pumps up, not sure which. I attribute it to what I have learned about the lack of availability of good hydraulic lifters. If they are aftermarket, it could very well be your problem. This is the reason I'm going to put a solid lifter cam and lifters back into my truck. At least they will all sound the same and not hear the same one or two clack away in the morning.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
red49 #1019179 04/03/2014 4:21 PM
red49 #1019183 04/03/2014 4:29 PM
H Online: Content
Noisy hydraulic lifters were a problem when these engines were new, and 50+ years of use hasn't improved the situation any. Whenever an engine stops, at least a few valves are open, and the constant push of the valve spring against the lifter causes it to leak down and bottom out. It's supposed to refill as soon as the engine is restarted, and oil pressure builds up, but sometimes it takes a little while for that to happen. We used to run a thin solvent-type oil additive such as Bardahl or Wynn's Friction Proofing to clean out the check valves and help the lifters function right, but I'm not sure if those products are even still on the market. Add about a pint of Diesel fuel or Mineral Spirits to the crankcase and run the engine at fast idle for 10-15 minutes before an oil change, and the same cleaning effect will happen. Just don't drive the vehicle and load the bearings while the solvent is onboard.
red49 #1019332 04/04/2014 3:23 AM
1951 3100 Chevrolet
red49 #1019334 04/04/2014 3:26 AM
H Online: Content
Diesel fuel is cheaper, and it does the same thing!
red49 #1019335 04/04/2014 3:35 AM
Just showing it's still around !!!
1951 3100 Chevrolet
Sounds like it couldn't
hurt and maybe it will help I will give it a try. Thanks guys.
red49 #1019386 04/04/2014 2:36 PM
What do guys think about Seafoam?
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
red49 #1019401 04/04/2014 3:48 PM
My Blog
