| | | Forums66 Topics128,078 Posts1,056,051 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 12 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 12 | First my thanks for all the wonderful advice, parts and direction this site has provided in the reconstruction of my 1952 3/4 ton.
I have had a Gear Vendors overdrive and a 4:10 rear installed so doing 70 mph is now pretty easy. I also have one of those exterior steel reproduction sun visors installed.
So for those of you with steel sun visors, what's a safe speed limit to keep the unit from tearing off?
Hilary Smith Northern Virginia
Hilary Smith
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I know guys that run them and drive over 80 MPH lots with no problems. I would just periodically check it to make sure it stays tight and secure. | | | | | Joined: Aug 2011 Posts: 12 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 12 | Great news! Thanks so much for taking the time to share your knowledge.
Hilary Smith
Hilary Smith
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Mine is made of aluminum. I didn't think speed would be an issue, hope to get mine on soon. | | |
