| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | I've read on here of guys swapping a 70's front crossmember to a 60's truck to gain the disc brakes, but will the same work for a one ton? I have a 76 one ton rolling chassis as a perfect donor. I was just wondering if anyone has done it, or heard of the swap.
Dave
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" Elanor Roosevelt
1966 c-10 stepside 1966 c-10 fleetside 1964 c-10 fleetside 1964 c-10 short bed 1964 c-30 flat bed 1964 c-60 dump truck 1968 Impala 1969 Nova 1971 Nova 1975 LUV 1976 C-30 1977 K-20 1966 SS El Camino
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | | | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | thanks ron, have you tried it?
| | | | | Joined: May 2009 Posts: 99 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 99 | Well, its been a while since I've posted here, but I saw this thread and thought I could add something.
I have a 66 1 ton and I swapped a 73 front crossmember. IIRC, 73-87 will work. I didn't have to swap the cross member, I could have just swapped the control arms and steering assembly. The control arm bushings are the same. The ball joints may be the same, but I went with the '73 ball joints. All the steering replaceables were for '73. Shocks for the '73. If you swap the CM, some drilling to add 1 hole and oblong another is needed. The steering assembly from the later model is required. It would help a lot to bring the sway bar to the older truck, also.
Your old rims will probably not fit. The older hub centric wheels will not fit over the later hubs and the calipers will be too big to fit into the wheels. But you needed new wheels anyway.
You will have to replace the brake lines and the proportioning valve for the 2 circuit system (disk front-drum rear).
If you plan on putting an LS engine in, then you will want the SBC motor mounts with the cross member.
Good luck, its a great upgrade.
Dave.
Dave.
What's the last thing a red neck says, "Hey guys watch this." What's the last thing a redneck hears, "Go ahead Bubba, you can do it."
Build plan: 65 Chevy one ton, 5.9L Cummins HO, NV5600 six speed, 2wd 1972-1987 IFS disk front, frame off restore/mod, custom dump/flat bed, Alcoa rims, Dana 70 3.73:1 duals drum rear, plush interior, Guards red with Marine Corps decals. Donor is retired 2002 Ram 2500, 194K miles.
| | | | | Joined: Apr 2006 Posts: 78 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 78 | Thanks Dave,
Awesome! Thanks for the info. I believe the old girl is going to stop better now than she thought she would. It's an old welding/oil field truck that I bought for 300 from a guy who is very sorry he sold it to me now that I have it running.I invited him over for a BBQ and fed him like a king to make up for it. It has a 283 with a granny 4 speed. I rebuilt the distributer and carburetor, tuned it up. I'll get some pics eventually...
Dave
