Brrrr
place holder
5 members (Shade Baby, ShopRag, Hugh63c10, dt235sd, Perro), 85 guests, and 2 robots.
Topics128,271
Posts1,058,417
Members48,485
#1018722 04/01/2014 4:29 PM
I've read on here of guys swapping a 70's front crossmember to a 60's truck to gain the disc brakes, but will the same work for a one ton? I have a 76 one ton rolling chassis as a perfect donor. I was just wondering if anyone has done it, or heard of the swap.
Dave
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1964 c-60 dump truck
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
should work
ron
thanks ron, have you tried it?
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
Well, its been a while since I've posted here, but I saw this thread and thought I could add something.
I have a 66 1 ton and I swapped a 73 front crossmember. IIRC, 73-87 will work. I didn't have to swap the cross member, I could have just swapped the control arms and steering assembly. The control arm bushings are the same. The ball joints may be the same, but I went with the '73 ball joints. All the steering replaceables were for '73. Shocks for the '73. If you swap the CM, some drilling to add 1 hole and oblong another is needed. The steering assembly from the later model is required. It would help a lot to bring the sway bar to the older truck, also.
Your old rims will probably not fit. The older hub centric wheels will not fit over the later hubs and the calipers will be too big to fit into the wheels. But you needed new wheels anyway.
You will have to replace the brake lines and the proportioning valve for the 2 circuit system (disk front-drum rear).
If you plan on putting an LS engine in, then you will want the SBC motor mounts with the cross member.
Good luck, its a great upgrade.
Dave.
Dave.
What's the last thing a red neck says, "Hey guys watch this."
What's the last thing a redneck hears, "Go ahead Bubba, you can do it."
Build plan: 65 Chevy one ton, 5.9L Cummins HO, NV5600 six speed, 2wd 1972-1987 IFS disk front, frame off restore/mod, custom dump/flat bed, Alcoa rims, Dana 70 3.73:1 duals drum rear, plush interior, Guards red with Marine Corps decals. Donor is retired 2002 Ram 2500, 194K miles.
Thanks Dave,
Awesome! Thanks for the info. I believe the old girl is going to stop better now than she thought she would. It's an old welding/oil field truck that I bought for 300 from a guy who is very sorry he sold it to me now that I have it running.I invited him over for a BBQ and fed him like a king to make up for it. It has a 283 with a granny 4 speed. I rebuilt the distributer and carburetor, tuned it up. I'll get some pics eventually...
Dave
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
