0 members (),
148
0
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | I installed Dolphin gauges in my 1961 Chevy C10. I am using the original fuel tank behind the seat (and the original sending unit).
My Dolphin Fuel gauge reads about a half a tank of fuel when the tank is full. I called Dolphin tech help line.
I was told my original sending unit is a 0-30 OHM unit. And the Dolphin gauge needs a 0-90 OHM sending unit.
So I need a sending unit that will fit my tank which will also work with this Dolphin gauge.
I was told that GM used 0-90 OHM sending units from 1964 trucks and after. I am not sure if my source is accurate with this information.
Can anyone verify if all I need to do is find a sending unit from a 1964 and after? In other-words, what sending unit will work for my original gas tank AND work with my new Dolphin gauge?
Thanks in advance, Brian | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brian, All the scoop you got was correct. I don't know what year GM sending unit would fit best, but if all else fails, Stewart-Warner has universal units in 90 ohms....I think! EDIT. More research indicates the 90 ohm sender was used in '65 and later, so it might take a hands on check with a meter to be 100% positive. I have enclosed a interesting link on sending units. http://yogisinc.com/results.cfm?Category=376 Stuart | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Brian,
I sent you a email, did you get it?
Jake | | |
