5 members (JW51, C10 - C90 Bill, Gray_Ghost, Leo, Hotrod Lincoln), 111 guests, and 2 robots.
Topics128,100
Posts1,056,177
Members48,436
#1018558 03/31/2014 10:18 PM
Just curious. What's the physical size difference, roughly, between the 228-302 and the 503 straight six?
The 503 is a huge, heavy low RPM engine. A 302 was used in up to 450 series. In 55 a 503 appeared in a 630 series. The hood on a 630 series is about 6 or 8 inches longer in a 630 series than a 450 series if that tells you anything. My first semi was a 550 series with a 370 V8. The 370 turned out more HP than the 503 and the 550 series uses the same hood as a 450 series.
As I figured. I'm looking for an engine for my truck and my friend finds a 503 and says "there you go, problem solved!"
Thanks for the info smile
H Online: Content
What's the price on that 503? I might be interested in acquiring it.
Thanks!
PM sent, Hotrod
