3 members (Gdads51, Gib70, 1 invisible), 86 guests, and 0 robots.
Topics128,078
Posts1,055,935
Members48,430
#1018060 03/29/2014 11:03 PM
Can someone tell me if there is a difference in length between long bed and short bed trailing arms for a 66 - 72 C10. I'm in need of a decent set and do not want to buy something that does not fit. My truck is a short step side bed.
By the way, if someone has a set of trailing arms let me know!
Contact Tony.
He has everything you need.
http://www.4-5-6chevytrucks.com/
Thom Masterson
I believe all the trailing arms are the same for a C10. The C20 and C30 appear to have a deeper cross section, or thicker iron and are slightly different than the C10.
Originally Posted by Rich 5150 69
All the trailing arms are the same dimensions, just the 20`s were reinforced from the factory.
Here is a link to a thread that has some discussion about trailing arms. See post #2.
Hope that helps. thumbs_up
Originally Posted by Bats62Chevy
Contact Tony.
Rich can also help if you need 60-66 parts
Rich Sisnero http://www.stovebolt.com/RJ/
Classic Parts has repro new trailing arms too: http://www.classicparts.com/1960-72-Rear-Trailing-Arms-Repro-pair/productinfo/74-871/#
