| | | Forums66 Topics128,074 Posts1,055,911 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 3 New Guy | | New Guy Joined: Mar 2014 Posts: 3 | Can someone tell me if there is a difference in length between long bed and short bed trailing arms for a 66 - 72 C10. I'm in need of a decent set and do not want to buy something that does not fit. My truck is a short step side bed.
By the way, if someone has a set of trailing arms let me know! | | | | | Joined: Nov 2009 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 119 | Contact Tony. He has everything you need. http://www.4-5-6chevytrucks.com/
Thom Masterson
| | | | | Joined: Feb 2014 Posts: 215 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 215 | I believe all the trailing arms are the same for a C10. The C20 and C30 appear to have a deeper cross section, or thicker iron and are slightly different than the C10. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | All the trailing arms are the same dimensions, just the 20`s were reinforced from the factory. Here is a link to a thread that has some discussion about trailing arms. See post #2. Hope that helps.  John | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | |
