| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 11 New Guy | | New Guy Joined: Sep 2012 Posts: 11 | I have a 1953 one ton looking to put a Cadillac 500 into it and I was just wondering where to place the motor? I've heard just after the original front crossmember but I'm looking for a more accurate measurement. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I have pictures of a 51 half ton with a 500 Cad I did and it looks like the right head is very close to the firewall and the left head clears by about one and a quarter inches. I had to go by firewall clearence for judging where to place the engine. If your using a recessed aftermarket firewall then maybe other measurements will work. The engine, 400 Turbo Hydramatic trans, and factory radiator all fit in without cutting the cab, floor, or core support. Run a 3.08 rear and it could have EASILY pulled one down into the 2's.
Evan
| | | | | Joined: Sep 2012 Posts: 11 New Guy | | New Guy Joined: Sep 2012 Posts: 11 | The fire wall does give me a better idea as to where it should go I am planning on making a new fire wall just to clean up the look. Actually I'm making all the parts myself so the more pictures and dimensions I can get the better. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | I always place the engine as close as possible to the firewall, keeping enough room for clearance for everything when the engine moves. | | |
