| | | Forums66 Topics128,032 Posts1,055,438 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I have replaced all my brake lines and two wheel cylinders. I have rebuilt the other two cylinders and the master cylinder. My brakes still do no hold pressure. After a couple pumps they hold, but then if you let off, in less than a minute the pedal will go back to the floor as soon as you step on it. I have fixed all the leaks I could find and bled the brakes several times now. Is it possible my master cylinder is bad but not showing signs of a leak? Maybe my problem isn't air in the system but just a bad part? Seems like a pretty simple system but I cant figure this out. 1950 3100 Chev. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Do you have all the shoes adjusted up? If not, you should do that before proceeding. If you had a gap of say around .10 " between each shoe and the drum, you would use up all the travel in the master. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If shoes are good, as said. It really does sound like MC so far. Revisit the assembly sequence of parts again. Take it out and inspect inside. Rubber installed in correct direction and so on.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Been there for sure. I found a sequence if you like that works. 1, Adjust each brake shoe at each wheel until it just touches the drum. 2. Bleed each wheel cylinder starting with the right rear, left rear, right front, left front. 3, Wait, yep wait for about 1 beer, or what ever seems like 10 minutes. 4. Try that pedal. If good, repeat step 3 and smile. If it still is soft then pull the MC and see what you have.
Steve H
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Have you adjusted the pushrod that goes into the master cylinder? | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I will revisit the brake shoe adjustment and go from there. I have not even thought of adjusting the push rod. I could play with that also. One of my considerations is I already need to order a new water pump and NAPA can also get me a master cylinder. I don't want to spend that money on a part I don't need but I have a 20% off coupon good till the end of the month so if I do need one now is the time to order and save a little cash. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You probably havn't got the shoes adjusted right. The huck brakes have 2 adjustments on each wheel. You can tell which way to turn the adjustment by picktureing the cup on the ends of the wheel cyl. They are all right hand treads. Adjust each one till you get a heavy drag & back it off 4 notches. There may be some drag in it yet but will smooth out when they get seated in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The TF adjustment on the MC is just a cammed bolt. Must not take much to make a big difference.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | What did it for me when that happened years ago was bench bleeding the MC first. Sounds like the lower MC has air in it. | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | I think I found the problem, or at least a problem. Not sure how this was hidden so well before but when I was adjusting the front left shoes I looked over and happened to notice a drip from user the master cylinder with every few notches. I crawled under and found fluid was escaping backwards into the boot over the push rod. I believe I probably tried to rebuild a cylinder that was just out of limits and its time to break down and replace it. I will pull it part and check to see that I put it together correctly first. Either way I appreciate the advice as always and will follow the sequences of events posted here and hope that I get it taken care of. Its ready to drive after this. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Good catch. That boot can hold a lot of fluid. At least you were looking and thinking. That is most of the battle.
Steve H
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I believe if MC was not pitted/scored/rusted and you just soft reamed it, it would not be out of spec. The rubber does not wear steel. Replacing it using your discount would not hurt either. The last one I built (TF) I had to assemble backwards to what instructions said. I could not load it into the end shown on instructions.
