1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 40 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 40 | Replacing a 327 with a new goodwrench 350.I know they changed the flywheel to a balanced one somewhere a long the way,maybe mid 70s.What is the correct ones for the goodwrench? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Small block chevy engines with the exception of a 400 are internally balanced. If you order a replacement engine to match what you are removing the original parts should be the same.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | In 1987 the 350's changed to a one piece rear main seal. The crankshaft is different and uses a different flywheel and balancer. Do you know what rear seal type your motor uses? | | | | | Joined: Mar 2014 Posts: 40 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 40 | Yes it has the 2 piece rear seal.I am replacing the balancer because of age but planned on using my flywheel.I know the 400 is externally,but the parts stores show a balanced flywheel for a 350. | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | If both engines use a 2 pc rear seal then they can interchange. As stated, once the SBC began using the one pc rear seal, then those crankshafts also require a flywheel/flexplate with a counterweight on them to be balanced, and will not interchange with an engine that is a 2 pc rear seal. The "balanced" terminology from the parts store could be hinting that the app he lists one for is the later counterweighted one.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Mar 2014 Posts: 40 'Bolter | | 'Bolter Joined: Mar 2014 Posts: 40 | Thanks that makes it tie together.Kinda been out of this game a few years.I used to know most of the interchangeability of bowtie parts,but age, time,etc takes place of that stuff. | | |
