0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | I bought new floor seal and flange for the steering column of 57 3100. New ones have a larger hole than the steering column diameter. I understand it needs to be slightly bigger to be able to slide the column through the seal, but there is probably 1/8" to 1/4" of space completely around the stock column that is not sealed. Am I missing something here??
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the rubber covered metal piece should have a loose fit, but the actual seal should be snug - if not you might have bought from the wrong place  Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 |
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2007 Posts: 69 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 69 | I bought that same part from Classic Parts. The hole in the sponge seal is the same size as the hard rubber flange. Guess I'll buy another and see what I get. | | |
